Hi there
You can check via the TV:
Or you can check on Sony's Support Website:
Also, if you have a smartphone or tablet, you can install Sony's App (Available on iTunes or Google Play) - Which will push a notification to your phone/tablet informing you that a new firmware is available
Google Play:
https://play.google.com/store/apps/details?id=jp.co.sony.support&hl=en_GB
iTunes:
https://itunes.apple.com/gb/app/support-by-sony-stay-informed/id948089375?mt=8
Cheers
Hi there
Google Play:
iTunes:
Cheers
