Constant orange light and remote not working
Scottmc1
Explorer
My remote does not work, I have tried it on my other Sony’s and it works fine.  The orange light is on constantly.  I think it 1 or 2 reasons.
1. Turned off during a software update?
2. Timer set
either way I can’t get it to do anything.  I have tried a hard reset about 50 times and that doesn’t work.
Help please
scott
3 REPLIES 3
Joe_Dohn
Specialist
What model TV are you referring to? What software version is it on?
Scottmc1
Explorer
Hi, it’s a KDL-32WE613 but I don’t know what software it is on as the remote doesn’t work so I can’t see what software it is on.  I can only turn it on using the the buttons on the back
Joe_Dohn
Specialist
Use this article to make sure that the remote is the one not working and not the TV's IR receiver.
