Bluetooth is disabling itself randomly on KD-49XG8096
SOLVED
profile.country.GR.title
trospeg4
Explorer
Dear Community,
Since a few weeks I noticed that Bluetooth is disabling itself at seemingly random times.  It also cannot be turned back on without a reboot of the TV.
I think the issue started after the last firmware upgrade as it was not happening before.
Current FW: PKG6.6575.0259EUA
Does anyone face a similar issue? Any suggestions to solve it?
Thanks & Regards,
Petros
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
Try updating to the latest software version and let us know if that solves it for you.
2 REPLIES 2
Joe_Dohn
Specialist
trospeg4
Explorer
I installed the v6.7140 update some days ago and it seems that the issue has been resolved as it doesn't appear anymore. Hopefully it stays so... Thanks for the tip @Joe_Dohn  ðŸ˜Š
