A1 Wall Mount
gordonmw
Explorer
A1 Wall Mount
Hi, Just had Tv a few days loving it.But probably  not getting the best out of it yet?? And was looking for a wall mount but don't seam to be able to find one anywhere?? Can anyone Help..
3 REPLIES 3
profile.country.DE.title
IamNic
Hi @gordonmw,
this site might help you find the correct wall mount:
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/140959/related/1/session/L2F2LzE...
It seems to be called "SU-WL450".
- Nic
gordonmw
Explorer
Wow that quick..:grin: Thanks IamNic. Yes been on there  what I should have said is I cant find the  mount for sale :frowning2:
Anonymous
Not applicable
Hi Gordon,
You might want to contact Sony Partner EET, they sell all kinds of spare parts & accessories.
They have some of these SUWL450 wall mounts listed as incoming stock at time of writing, as you can see here.
However, you might want to check with them if it's indeed the right model for your A1 just in case, because they don't seem to list it as a compatible model on the page, although as Nic said that seems indeed to be the one you need.
Best,
Arthur
