43xf8096
profile.country.LT.title
aivaras123-
Explorer
43xf8096
Hello, i have this model for a month and I noticed that, when you cleaning the sreen with wipe or something, the panel is moving for around 2mm from frame. Is it normal or I have go to replace this? I was on the shop where I bought it, and I touched the sreen of bigger size model (49xf8096), and it also moved, but not that much as mine.
3 REPLIES 3
aivaras123-
Explorer
Ok then, I went into another shop, and touched exactly same model with same size, and it moved like mine. So I think it's normal..... But i must notice that build quality in this brand gets lower
Pascale_F
Moderator
Hi aivaras123-,
Welcome to the community.
It sounds like it's normal then.
Thanks,
Pascale
aivaras123-
Explorer
Maybe there is some other users of this KD43XF8096? If yes, maybe you can check if your panel behave like mine? I'm very interested in this :slight_smile: thanks
