I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
Hi,
Well, I have had a call from Sony CRO office yesterday, and they have given me a week for them to release all the software and send it to the Android TV units, for the all the units to work.
Sony are fully aware of the Android problems, and they are mostly trying to pass the buck, but when you just keep on at them and stand your ground, they do sort of, well not admit, but say they "understand" the issues with the units.
I am promised a phone call from Sony about these ongoing and up and coming problems, and if it is not completely up to date, working, with the Netflix, HDD Record, Skype, TV guide wait...well, we know the list is getting endless....i will be liable for a return.
Lets see what happens...i will keep this posted.
Thx
It's just not android issues that customers are experiencing with the new 2015 android sets. I am having 3D woes with a two day old 43W809C model where the TV will not register/pair with the Sony TDG-BT500A 3D glasses, followed the register instructions several times but getting no message on the bottom right of the screen that the glasses are paired to the TV which you are meant to get, hence no 3D. Also had to do a reset after the "Action" button on the remote failed to work. I don't hold out much hope that the 3D issue will be fixed as Sony has a terrible reputation regarding 3D issues. Terrible pity as I am very happy with the TV picture wise but if I get no satisfaction with the 3D problem in the next few days then it goes back for a refund.
I Also gave an honest review, so i would suspect it will also be binned, but lets be honest what do sony expect.
I have a simple issue, tuesday my 14 day period is up,i have to return the tv or keep it as is. I have spoken to Currys, and they state that their agreement with sony, means after 14 days i would have to accept a repair, a refund is not possible. I explained about the issue being from purchase but that does not count because i know about it. The advisor said if it was him, he would request a replacement as the 14 day period starts again.
New to this my very first post
I too have had similar issues to above.
Specifically when I try a full system reset, the set is blinking so that each screen only briefly appears making it very difficult to navigate and see exactly where you are and what you selecting to move onto the next screen.
I should point out that the Netflix or Youview app does not even appear as a choice. I currently have a youwiew box which I am using and when streaming netflix from my sony Blue ray certain streams (from netflix only so far observed)have produced intermittant snowing in dark areas (comes and goes)
Additionally I wanted to listen to a little music so connected my sony walkman, I found that it would freeze at random points to a white screen and stop playing, would resume again if I backed up, but the same would happen again.
Isn't there supposed to be a web browser with this tv?
