PMB
SOLVED
profile.country.en_GB.title
rickybrown
Explorer
PMB
Hi there
I have asked this question before but it was on the US site by mistake. The question is does enybody know if there is a PMB app for the apple ipad.
Many thanks in advance for your help.
Message was edited by: rickybrown
1 ACCEPTED SOLUTION
Accepted Solutions
Watashiwateshdes
Contributor
Hi rickybrown
Picture Motion Browser was designed more as a program for use on a laptop or desktop. There is actually an app called "PlayMemories" available. Not really specifcally PMB but it is designed to work with the wi-fi cameras that are available.
More info on the app can be found here - https://itunes.apple.com/us/app/playmemories-mobile/id489191124?mt=8
You may find with the older cameras available, the iPad camera kit may be your best bet to import photos.
Hope that helps
2 REPLIES 2
Watashiwateshdes
Contributor
Hi rickybrown
Hope that helps
profile.country.de_DE.title
cmosse
Contributor
For iOS the "PlayMemories onine" app is available (free). Picture Motion Browser or PlayMemories Home is noat available for Apple users.
