Introduction
An oft overseen possibility to install camera applications is by using your camera to install these.
By using WiFi you avoid the USB connection to the computer and possible misfits between the Play Memories Camera Apps website in your browser and your camera.
We'll explain it with the example of installing the Smart Remote Control App to remplace the Smart Remote Embedded in your camera.
The Smart Remote Control App enhances Remote Control quite a lot.
The difference in possibilities is quite obvious.
Uploading apps to your camera applies to the following camera types:
Let's go.
