Lens compatibility
profile.country.en_GB.title
bonnzo
Visitor
Lens compatibility
Will my current Minolta AF lens work fully with the Sony A65V body?
2 REPLIES 2
Si_1966
New
Hi Bonnzo, A warm welcome to the Sony forum. You have not given us much detail on the lens, if you can give use the focal lenght or zoom range or model number that would be excellent. However, all Minolta A mount lenses will work with the Sony A65V.
Cheers
Si
profile.country.de_DE.title
cmosse
Contributor
Hello
All your Minolta AF lenses (genuine Minolta/Konica Minolta brand) will work with the A65.
As a reference you can also take a look at the official compatibilty table on the Sony support site:
http://www.sony.co.uk/support/en/product/SLT-A65V/compatibility
Michael
Message was edited by: cmosse
