DSLT Alpha owners: What improvements would you make to your camera?
SOLVED
profile.country.en_GB.title
p4ult212
Contributor
We constantly strive to improve our products, so we’d really appreciate your feedback on what changes you would make to your Sony DSLT camera to make it even better.  Whether it’s to do with the design, usability or specific features just let us know what camera you use and what changes you’d make.
64 REPLIES 64
dnwinterburn
Visitor
The cover for the USB connection only just allows the USB plug to fit in. It seems like the flexible plastic "hinge" might break soon when used regularly.
I second that!
gvelladvd2005
New
Digital level gauge added to the A35 please. In fact, I was quite dissapointed to find that the A35 does not have the digital level gauge, despite the sony website saying that it does under LCD on the A35 specifications page.
Hopefully this will be added as part of a future firmware upgrade?
Cheers
MarkHoldgate
Visitor
I agree totally. If you use shutter priority settings the 10fps is not achievable and the EVF / screen goes black mid way through rapid shooting which is very very very irritating when I'm trying to take shots of fast moving aircraft. I use a Sandisk 16GB Extreme 20MB/s SDHC card and I wondered if I had a problem with it or the camera so I went to my dealer to check if my camera was actually working properly. Apparently it only gives 10fps when set to "auto" and the guy at the dealership queried what the problem was!
The other improvement I would make is to make the body bigger - I have large hands and where my fingers wrap around the grip and my fingertips touch the body I have worn away some of the rubber skin from  it - within the first 6 months of owning it which makes me not very impressed!
I consider myself a bit "old-fashioned" in so much as I like to look through the EVF to capture my shot rather than look at the LCD screen. The other reason is that you have more control over "shake" if the camera is held up to the eye and you can balance better to get a steadier shot. Trouble is the EVF is not good for shooting in MF because it is incapable of producing a sharp image so you never know whether its on the money or not until you've taken the shot. I know that the focus point will illuminate green when in focus and the shutter button is held part way down but I'm not always convinced that it is focussed on the actual part of the shot I want!
I would also like to see a dual display - one for settings and the other for live view.
Also why not a number of user-defined saved manual settings that will allow the user to quickly change the settings to accomodate different types of subjects by retrieving them from the memory?
A detachable battery pack that fits on the base of the camera and provides a longer battery life than the standard internal battery?
Finally the flash hotshoe: Why isn't it a standard design to be compatible with other non-Sony devices? Canon and Nikon have a standard design so why not Sony?
Message was edited by: MarkHoldgate
Josem82
Member
A33 - Simple, just improve the battery life...
Jabbathehut73
New
Hi, I use the A35 mainly for film.
A couple of firmware improvements would be:
1. Configure a button (say live view) to hold focus while pressed when recording. (some older minolta Xi lenses have such a button)
2. Mjpg is already available - why not allow filming 720p in mjpg? Easier editing on PC and SD card sizes are growing + prices are coming down. Would be a nice choice.
3. More control of settings in video mode, for those of us who do have tripods etc...
Because video is in auto mode, it causes ios/ap lighting problems, flickering etc.. I would prefer to choose a constant setting and accept the cons.
4. AVCHD is recorded progressive (25fps PAL), but seen as 25fps interlaced in editing programs. Would be nice to be able to change properties of avchd file in say PMB.
5.Be able to to activate shutter release button for video filming in settings - thus being able to use a remote. A useful setting would be like on Point and shoot, Hold down the shutter to autofocus, fully press to film. I know it's not the point of a n SLT, but for video, it gives instant control in one button for recording when you don't have time to adjust everything. Professionals use higher end gear, the A35 is Entry - family birthdays etc...
Hope we amatuer film guys get some of the above....
mikeyp2000
Member
A77 firmware enhancement requests:
1) pal/NTSC switchable video for travelling videographers
2) manual mic gain control for audio in video.
3) video button to be customisable (like ael/iso buttons) or have an optional 'double press to record'.  I'm not alone in having quite a lot of 5 second movie clips of my feet, usually taken while flipping out the screen.
4) in the dedicated manual video mode (from the mode selector knob on the top left of the camera) allow the normal shutter button to start/stop recording. Using the record button is ergonmically unsound and in manual video mode the shutter button just doesn't do anything
That's all I can think of for video. Here are a few photo ideas
1) make the controls as responsive as the A55/a700. Even with 1.04,  there is still some control lag especially annoying in local AF mode and moving the active AF point with the joystick.
2) quicker EVF/LCD switching.  Even with 1.04 there is still some lag.
3) implement a Lowest Shutter speed to allow better control over autoiso
4) allow autoiso in M mode (yes I know it wouldn't be truly M mode then, but you would still have the option of selecting ISO manually of course). In this mode, still allow exposure compensation like in A or S modes.  (this would be a sport shooters ideal setup and would make many more sales)
5) allow full customisation of the Drive Mode, WB, top plate ev+/-, Movie and smart teleconverter and '?' Buttons.  You can already customise the ISO, AEL, AF/MF buttons so it should be simple to extend this to the others.  (ironically, you can change the ISO button but not the ? Button at the moment. Surely most users of a camera at this level/cost never use the ? at all)
6) not sure if this is possible but when using smart teleconverter, would it be possible to electronically stabilise the EVF view?  This would also be handy when using Focus Magnifier view.
7) implement tethering in the same way as on the a700. (very very important!)
😎 some kind of pixel binning to allow saving lower resolution RAW files (16 or 12mp choices would be ideal). I like the freedom/leeway granted by raw in tweaking exposure and WB but rarely need 24mp
9) fix the hung flash issue i described in another thread here
10) In MF mode, when I press the af/mf toggle button (rear top right of camera) the camera AF triggers in AF-S mode. All very nice but please add an option for it to trigger AF-C mode or AF-A mode.  This would be roughly equivalent to the canikon 'back button autofocus' that seems so popular with sport shooters
11). When zoomed in (focus magnifier) in AF mode and I notice focus is a bit off' I press the AF/MF button to adjust focus.  Sadly, it drops back to the zoomed out view.  It would be great if it stayed zoomed in and far more useful.
12) an 'OVF simulation mode' where the EVF always always shows the TTL view ready to take a photo.  After taking the pic, have auto review send the pic to the rear LCD only, keeping the EVF in live view mode.  When autoreview has timed out, blank or power down the rear LCD.  Reason: with the top plate LCD and ability to change settings in the EVF, I don't need the rear LCD for changing settings and often flip it inside out to hide it   I'd like to use it for autoreview only but the current 1.04 autoreview shows the image on the LCD and the EVF. With auto review off, the camera handles better but I keep having to press the playback button to chimp my photos.
12) bring back the steady shot indicator scale!  The a55, a700 and presumably many other alpha cameras had this little bar scale to show how steady you were holding the camera.  Very useful! But sadly it has disappeared from the a77
13) add 'steady shot on/off' to the list of custom features available on the customisable buttons. This would alleviate the missing steady shot switch, lamented by so many a700 upgraders.
14) for the shutdown sequence, park the lens at infinity FIRST.  Aftere that I don't care how long it takes to shutdown completely.  Try putting a lens like the tamron 90 macro back in your bag before the shutdown is complete. The wind-to-infinity currently as the last step can have dramatic effect on a camera in a crowded bag!
15) what happens to the "brightness" option in the creative styles?  The a700 had this but it's just not there any more.  Same for zone matching
16) JPG only modes are not available in with RAW.  Fair enough but couldn't the camera offer a warning then shoot a jpg anyway? Perhaps panoramas/hdrs could save the raw files as well as the jpg
17) customisable raw+jpg to allow different jpg sizes/qualities to be recorded beside the raw file. Again, the a700 had this.
18) NOise reduction off for JPG files.   The a700 had this.  The a77 has auto or weak only.
19) EXIF field for copyright info. After all this is supposed to be a semi pro camera isn't it?
20) EXIF info for focus distance and AF point used. (ok this is a minor one but occasionally of interest to me)
21) the AF points are black in live view. Against a dark background, they are almost totally invisible.  In LOcal AF mode, as I jog the active AF point around using the joystick, I'm almost guessing which point I have selected and need to to trigger the AF to make the active AF point light up green.  Combined with the lag between joystick action and AF point actually changing, this can be a frustrating experience.   I can't recall exactly how the a700 handled this but I never had a problem being able to see the AF points  perhaps the a77 points could turn red briefly while you are jogging them around and later on when composing, the live view could show them as a black box with a white outline. The screen resolution is so fine, an extra box of white pixels around each black box would hardly be intrusive and enhance the camera greatly.
Well, that's just a few ideas!  Don't get me wrong, the a77 is a fabulous camera.  My A700 is now sold and the a55 has gone the same way.  With a few minor tweaks, the a77 would be unbeatable for me and I'm sure the things I'm asking for are not hardware dependent.  In fact, I'd pay for some of the things listed above!
22) Bring back the quick navi user interface (as seen on a700/a900/a850) - often lauded as one of the best ever camera UIs
Cheers
(edit to add point 22)
Message was edited by: mikeyp2000
mikeyp2000
Member
A few more ideas for the A77:
1)  Implement a Contrast Detect AF mode for tripod work.  I believe the A580 can do this.  Even if it's not fast, it would be useful at times.
2) Invent an Auto-micro focus adjust facility.  If contrast detect focus (as in "1" above) it should be simple for the camera to calculate the focus shift from the phase-detect AF sensors and set the MicroFocus Adjustment automatically.
3) Allow multiple Microfocus adjustments for zoom lenses (Eg, wide, middle and long end of the zoom range)  It's not uncommon for a zoom lens to have different adjustment needs over the zoom range.
4) If I autofocus then use the focus magnifier to zoom in, it's great but if I notice a focus error and press the AF/MF button on the camera so I can manually adjust the focus, the viewfinder is zoomed out again.  The same happens if I use the M/AFC/AFS/C-AF dial on the front of the body.  It would be very nice if the view stayed zoomed in.
5)  Fix the banding issues seen when taking pictures with HSS flash and electronic front curtain shutter or implement an option to disable EFCS when using flash and HSS shutter speeds.
Cheers
profile.country.es_ES.title
FidoBoy68
Visitor
i totally agree with this list of features for future a77 firmware updates. Even considering that A77 is a fabulous camera, all of these fixes could add a perfect final touch to the annoying issues that i'm having after testing it for one month. I specially agree with manual audio level control (and also a on screen audio level meter), a long press or double click over the video recording button (this is really annoying cause right now i record so often 5 sec clips by accident), and also it could be great to allow switch from PAL to NTSC and viceversa, and disable cropping when recording video (even losing the steady shot feature) and allow 2.8 with video recording.
Also RAW panoramas, and HDR in raw mode could be nice.
just my two cents :wink:
kind regards,
profile.country.de_DE.title
magir75
Visitor
I wonder, whether this thread is still read considering that not that many posts have been made, yet...
The A57 introduced a cropping feature which enlarges the focal length and increases speed in order to achieve 12 frames per second. I think, this feature should be extended further - a huge advantage of the EVF is that it isn't limited to a fixed display ratio and size and it would be great, if I for instance decreasing the image size, the focal length is extended automatically (e.g. 24 MPix -> 12 MPix make a 18-55 lens zoom to 110.
Another issues, which is bothering A55 users is that HDR mode is disabled, when RAW mode is set - why not automatically disable RAW when HDR is selected? Currently, this is quite cumbersome to do.
p4ult212
Contributor
Hi, thanks for your feedback!  This thread is certainly read - and the feedback provided goes straight into the hands of the worldwide Product Marketing group, so the knowledge we receive goes straight onto the roadmap discussions for future releases!
Many thanks for taking the time to comment - we appreciate your thoughts and contributions!
