Xperia 5 battery issue
cccbadr
Member
hello  , dear dev Sony Xperia :
i'm tired , always take me charger with me .
the last update was catastrophic and panic with battery life and also performance software . some many time snapdragon 855 llaaagggy in android one , i didn't understing,.
#my-suggestion :
-battery life improvement .( stop application in background it takes a lot of Ram and Processing.
- adapt hardward with software for best user experiance and use all options in Snapdragon 855
- sécurité update , often any last update , we need more privacy here Sony.
*flagshap of 2020 doesn't mean he never takes care , in this moment i don't understood politice of Sony 2 phone no more update , look at apple , plz dev help us .
* Thanks
3 REPLIES 3
profile.country.NL.title
Strampke
You're challenging the device.
Stop apps active in the background from being active.
You're probably already aware of the settings.
Still:
- Stop background activity
- Set WiFi preferences to WiFi doesn't turn on automatically.
   - This means that WiFi will stay turned off as long as your device is locked
- Set WiFi and Bluetooth scanning off (better for privacy as well)
- Uninstall a lot of apps that you don't use every day.
cccbadr
Member
that need update not talking me friend , the application need to stop in background automaticly , i kewn i disable all option but this update was catastrophic for battery , update update and thanks
Anonymous
Not applicable
smartphones sometime face that issue after the update as the device starts to adapt with the new operations, and it should be rectified after that .
Try to check the information in this link, they can help: https://www.sony.co.uk/electronics/support/articles/00232835
