Touch sceen keeps freezing
Poppy90
New
Xperia 10 this year new. The touch sceen keeps freezing, the sceen it self's is still on working fine. I have to lock it and unlock it to get it working again. Any ideas?
4 REPLIES 4
CosmicTomato
Specialist
Try safe mode, it lets you know if there's anything installed that could be causing the issue, cause it literally only leaves the software of the phone running, it's from the restart menu, if you press and hold on the power off, it will ask you if you wanna restart in safe mode, press ok and give it a run for a while and check if it would still freeze, if it didn't try uninstalling some apps, clear out some space too. oh the SD card could be a factor too, try removing it and see.
profile.country.MY.title
GTYeoh
Explorer
Try disable side sense. that feature keeps bugging the screen making it feels frozen time to time.
profile.country.NL.title
Strampke
Hi @Poppy90
Did the answers help you?
Paulus6262
Explorer
Same problem here Las system update resolve the problem. 53.1.A.3.85
