NW-A45 Recent Transfers
Garth12345
Explorer
Hi , having a problem when transferring from music centre to NW-A45 . Whenever I switch on my Walkman and slide screen to the right and select the ‘recent transfers’ I just get a list of every album in alphabetical order and not the most recent songs/albums I’ve transferred ??
Tags (3)
6 REPLIES 6
Pascale_F
Moderator
Hi Garth,
Welcome to the community.
I'll see if I can find anything out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Garth,
Has the Walkman only started doing this recently?
Is the software up to date:
https://www.sony.co.uk/electronics/support/digital-music-players-nw-nwz-a-series/nw-a45
Win_88
Garth12345
Explorer
Hi , yes only just started doing it and music centre and Walkman are up to date
Win_88
Specialist
Hi Garth,
Do you have similar issues in any other folders when it comes to sorting?
Win_88
Garth12345
Explorer
Hi , no , everything seems fine folder wise . Thinking of a factory reset and restore
Win_88
Specialist
Hi Garth,
I think that's a good idea since the software's already up to date.
If the issue remains, try transferring files using Sony Music Centre instead of drag and dropping files just as a test.
Win_88
