clock radio remote control problem
profile.country.en_GB.title
eddoher49
Visitor
Hi folks, my 1st post.
I have a Sony clock radio  model ICFC1PMK2
The remote control is the small black type model number RMT-C1IP
It has stopped working so i assume batteries are dead
I am unable to extract the battery tray at the bottom of the remote
There is no screw and it is meant to prise out but it is jammed
Any hints? I dont want to break it by forcing it
Thanks
1 REPLY 1
Thalamus.
Champion
Hi  eddoher49,
welcome to Questions & Answers..:smileyhappy:
With the remote facing downwards there should be small lock type latch on the left of tray, move that slightly to the right & the tray should slide out quite easily..
If the battery tray is stuck then you may need to use some force in order to remove the tray but this could damage the remote or the tray so this has to be at your own risk..
