What are these sockets? VGC-RC204
challll
Visitor
I have recently bought a Vaio desktop VGC-RC204 .
On the back of this pc are six sockets that I really can't find any documentation about. What are these sockets used for?
See image (attached, sockets depicted on top).
Thankful for help.
9 REPLIES 9
joeneo13
Visitor
They are from the tv card
Thalamus.
Champion
Hi challll,
Welcome to Club Vaio, :slight_smile:
Page 45 of the RC204's manual may help you identify the various ports.. :slight_smile:
challll
Visitor
Thank you - I am sorry, but I am thinking about the six sockets below the display connectors.
Challl
challll
Visitor
Hi challll,
Thank you for this - I alreday checked that - the manual refers to a specification web page that lists different ports on the machine - but it does not say which is which.
Challll
chris_lewis
Visitor
In that case it the sound connections you are looking at, its probably a 5.1 sound card, the little square plug is for an optical audio out which is for hooking the PC up to a Surround sound amp.
HTH
challll
Visitor
HTH
Excellent - then I need to know what are the other 5 sockets - sorry for whining about this...
Challll :slight_smile:
Thalamus.
Champion
The image that you have posted is not very clear.. :slight_frown:
Does this help identify the ports..
Blencogo
Have you got them all?
In addition to the ones in Thalamus's guide, (4 X USB plus Ethernet) you have a 6-pin Firewire socket.
:thinking:
challll
Visitor
:thinking:
Thanks, I am getting close. A close look at the six ports give me the following (from left and to the right)
Top row of three:
Blue
green (marked front) : front speakers
pink
bottom row of three:
black (marked rear): rear speakers
yellow (marked center/woofer): woofer speaker
optical out: optical out.
This means I got all covered apart from the blue and green in top row.
The blue has a ---> symbol - means line in?? That would be compatible with the colors of the picture supplied by "Thalamus".
The pink is unmarked and without symbol - MIC???? Any MIC? I am afraid to try it out lest something is destroyed.
I think Sony should be able to tell me what exactly what to connect into these sockets.
Challll [
