Sony Vaio VGN FZ18M Motion eye problems
hodgevaldo
Visitor
Hi there
Since I have been using my notebook, the web cam has been up and down in if it wants to work or not. Sometimes a reboot works but even that doesnt work sometimes.
If I go to use the video capture utility i get the message below.
I useally try and use msn messenger where it cannot register the camera and also says its being used by another program.
VAIO Camera Capture Utility
An attempt to initialize the camera failed.
Please check if another software is using the camera.
OK
I am using windows vista.
Any help would be greatful
Glenn
0 REPLIES 0
