Recovery Discs For VGN-FZ21S
ilarvan
New
I have erase by mistake the recovery partition and i realised tha the recovery discs doesnt works, it seems to be bad burned. If someone have his discs can please upload it to rapidshare so to download it from here, this might be good move , because it isnt nice move from sony to pay this disc about 50$
Thank you
2 REPLIES 2
Thalamus.
Champion
Hi kakophonix,
welcome to Club Vaio.. :slight_smile:
Are you sure you have removed the hidden HDD recovery partition..?
To be 100% sure you can try to recover your vaio by doing the following: Start your Vaio and when you see the Vaio logo screen press F10 repeatedly this normally would start the recovery process..
If this does not work then you can order a replacement recover disc set from Sony Vaio Support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support , the last price I recall being mentioned was around €40..
profile.country.en_GB.title
pioprzyb9
Visitor
Hi, Have you got recovery discs for vaio fz21s, Can you upload discs on filesonic, thanx for replay
