The operating system on my Vaio stopped working. In trying to restore, I messed with the partitions I think.
I bought new System Recovery disks from Sony, but half way through the restore process, I get a message which says "failed to read the image file". The process then aborts.
I found a thread on this elsewhere but in ended without a solution.
Assistance would be greatly appreciated.
Try the advanced recovery
Thanks - how do I do this? I have already tried the three options for receovery given in the System Recovery disks.
Hi Golfmag2
What model Vaio do you have..?
Hi Golfmag2
Hi Golfmag2,
Have you tried re-setting the BIOS Defaults first?
Hi Golfmag2,
It's a bad disk then, I would contact VAIO Link and explain the problem with the disk
God, believe it or not, the System Recovery disks eventually worked. System now rebuilt and functioning.
Thanks all for your help.
Excellent news..
