Does my VGN-AR31E have Bluetooth ?
rawprawn
Visitor
Vista Home Premium,in the Vaio instructions which I downloaded it seems as if it should be there but I can't find it.
I have looked in Control Panel, and Device Manager but Bluetooth is not mentioned.
4 REPLIES 4
Blencogo
Hi rawprawn,
It does not mention Bluetooth in the connectivity specifications here: -
http://vaio.sony.co.uk/view/ShowProduct.action?product=VGN-AR31E&productFilters=retired&site=voe_en_...
Or here: -
http://support.vaio.sony.co.uk/specifications/specifications.asp?site=voe_en_GB_cons&c=0&s=VGN-AR&m=...
It is listed for the AR31M and AR31S but not the AR31E.
Unfortunately, it seems that the Bluetooth module is not fitted to the AR31E.
:slight_frown:
rawprawn
Visitor
Hi Blencogo
Thank you for the response, I had a feeling that it wasn't Bluetooth enabled but I wanted to be sure.
No problem, but my daughter bought me a new Mobile for Christmas and that's what got me started.
Blencogo
Hi rawprawn - Happy New Year!
A small USB Bluetooth dongle can be bought very cheaply. It should not be a big problem.
You are luck to have a daughter that buys something useful for Christmas!!!!
:slight_smile:
jumpsuit
Mind you my Playboy socks will be useful LOL
