Time sync from mobile?
profile.country.NO.title
ThorEgil
Member
Hi.
Is there a way to sync the time/date from the mobile app to the camera? When working with multiple cameras it would be very nice to get the exact time stamp on the photos.
Thanks.
7 REPLIES 7
The_Black_Rose
Specialist
Hi ThorEgil,
I'm not quite sure if this can be done. What's the model number of your camera so that we can check?
Cheers,
The_Black_Rose
ThorEgil
Member
It's an A7 III, but I guess there would alos have to be some functionality in the mobile or PC app to support this - and I can't find anything.
(My Olympus OM-D E-M1 gets a time sync every time it is connected to the mobile phone).
The_Black_Rose
Specialist
Hi ThorEgil,
I've just had a look into the help guide of the camera. I found that the camera on its own is incapable of putting a date stamp on pictures, this has to be done through Play Memories Home on PC. You can find this here: http://bit.ly/2IpjAnm.
Cheers,
The_Black_Rose
ThorEgil
Member
I'm not talking about printing the time on the picture. The camera will of course put the capture time and date into the metadata for the picture - like every other digital camera.
What I need is a time sync function from PC or mobile to get the correct time.
Win_88
Specialist
Hi Thor,
If you're only concerned with the time / date stamp in the metadata, you should have it set reliably by making sure the date and time settings on each of your cameras is set correctly.
Win_88
ThorEgil
Member
Exactly. And if there were a way to sync the date/time from PC or mobile it would be the best solution to get the excact time.
Vanilla_
Contributor
Hi Thor,
I see where you're coming from. I'll try to pass your feedback regarding this to Sony for consideration.
Best,
Vanilla
