Nex-5R Aperture setting
Agolindo
New
I have a second hand Nex-5R Camera with standard 18-55 mm. Emount lens..
It seems to work very well BUT I am unable to set the Aperture when in A Mode nor set the Shutter speed when in S Mode. However I can set the shutter when in M Mode, but not the Aperture.
Can anyone tell me if this is:
1 A fault
2 A setting problem
3 Something that can be fixed.
I have tried to load a sftware version update but already have the latest one so installation is refused.
2 REPLIES 2
Pascale_F
Moderator
Hi Agolindo,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Agolindo,
This sounds a bit unusual, as you should be able to set the f number in the A mode, the camera automatically sets the shutter speed and ISO sensitivity, while in the S mode, the camera automatically sets the aperture and ISO sensitivity. So, when you try to use the control wheel dial to change the aperture/ shutter speed, does the camera display an error?
Cheers,
The_Black_Rose
