flash for nex-6
profile.country.DE.title
canach2002
Visitor
flash for nex-6
hi,
looking for a not too big external flash for the nex-6 -- any ideasa?
regards
4 REPLIES 4
profile.country.en_GB.title
blaireau_photo
Visitor
Hello canach2012 - Welcome to the Sony Forums :slight_smile:
As this is naturally a compact camera, you may find that attaching an external flash makes the whole setup a little 'top heavy.' Having said all of this, the camera does have a standard hot shoe, meaning that it will be compatible with a variety of lenses (in some cases, an adapter will be required). The HVL-F20 flash is around £100:
http://www.amazon.co.uk/product-reviews/B0057XBH70/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
For this particular flash, you will also need to purchase an ADP-MAA adapter. These are available online for around £20-£25.
Thanks,
Simon
profile.country.de_DE.title
cmosse
Contributor
UPS, this can be confusing as there are actually 3 different HVL-F20 around:
  • HVL-F20S is not compatible with the NEX-6 as it features the smart accessory terminal.
  • HVL-F20AM is compatible but the ADP-MAA adapter is required
  • HVL-F20M is compatible and already features the right Mulit Interface shoe for the NEX-6
canach2002
Visitor
Many thanks to all...
So best will be to wait until end of may when the F20M will be available...
regards
Klaus
blaireau_photo
Visitor
Hello again :slight_smile:
Thanks for the additional input cmosse :slight_smile:
Simon
