convert a700 to black and white photography or infrared
SOLVED
profile.country.sv_SE.title
tothrnv
New
Hello!
Ivé got me a new A77 and i havent any use for my old so , is it possible to convert a700 to black and white photography or infrared?
Regards Tony
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
blaireau_photo
Visitor
Hello Tony - Welcome to the Sony Forums :slight_smile:
I am unsure about an 'infrared' mode, but you can definitely preset the camera to take black and white shots. If you scroll through the creative styles available, you will see the option to take Monotone shots - the modes are described on pages 67-69 of the manual:
http://pdf.crse.com/manuals/3282943131.pdf
Thanks,
Simon
3 REPLIES 3
blaireau_photo
Visitor
Thanks,
Simon
profile.country.de_DE.title
cmosse
Contributor
if you want "true infrared" photography with the infrared protection filter removed from the sensor you can contact following speicalised service (it is based in Germany but English should not be a problem): http://www.h-maccario.de/wordpress/?page_id=37 Price will be > 300€
tothrnv
New
Thanks for the replies, found it on the pages you specified in the manual.
so thanks
