A7C II - SDXC V90 warning message
0073540500008048
Explorer
January 2024.
SONY A7C II,  fw 1.01
I have recently been getting the message 'To perform shooting with this setting, use a memory card higher than SDXC V90.' in video mode.
I get this with Sony Tough G-series cards and ProGrade V90 cards. Camera is set to record XAVC-intra frame, 1920x1080, 25P so not particularly high data rate.
The A7C II only has one card slot. My SDXC are the fastest cards currently available. The camera doesn't have a CFE type-A slot.
I can of course hit OK and carry on shooting as normal but this looks like a software bug?  maybe worth letting the engineering team know?
6 REPLIES 6
It should only be a warning message that appears as a precaution.
0073540500008048
Explorer
thank you for the reply.
My point is the camera is telling me I need to use a card that doesn't even exist (yet).
It's like they have ported the software from another Alpha camera (maybe the A7 IV?) but forgot to delete this message.
danardeng
Contributor
I suppose that it's a software bug.
Are you able to ignore the message and take your clips?
@danardeng, @0073540500008048 wrote:
"I can of course hit OK and carry on shooting as normal"...
0073540500008048
Explorer
well, a did bypass the message a couple of times but then it suddenly wouldn't allow me to record anything at all so I had to do a factory reset (which wiped all my custom settings too).
It's behaving now....but for how long I don't know?
danardi78
I've sent your case to the support, probably someone will contact you soon.
Please, tell us how it's going
